12-05-2017 12:57
12-05-2017 12:57
Just taken delivery of a swanky new Ionic today - build quality is very good - and completed my first run tonight to compare with my Suunto Ambit (bit of a beat up old veteran now about to be retired).
What has drawn me to the Ionic is the development tools available.
So my question is this: Where are the Developer tools in the Android Fitbit App? I know where they are on the ipad, but I won't be lugging the ipad around a marathon with me!! Am I being blind? Are they in a different location on Android to the apple app?
Thanks
Rob
Best Answer12-05-2017 14:04
12-05-2017 14:04
If you've logged into studio.fitbit.com and accepted the developer enrolment, and your Ionic is running version 27.31.1.16, then the developer menu should appear in the mobile app, under Ionic.
If it's not appearing there, ensure your mobile app is up to date, and then try logging out of the mobile app.
12-05-2017 14:04
12-05-2017 14:04
12-06-2017 04:15 - edited 12-06-2017 04:16
Ah yes - that solves that one then. (Logging out and back into the android application.)
Thank you.
