05-02-2018 08:12 - edited 05-02-2018 08:19
I'm trying to display some content that is past the viewport, a sort of "second screen" without the need to actually have a second screen. Here are the basics:
index.gui
<svg id="page" class="portrait-view" pointer-events="visible">
<g id="screen1">
[watchface stuff]
</g>
<g id="screen2">
<svg id="stats" x="0" y="300">
[stats stuff]
</svg>
</g>
</svg>index.js
I have a function that moves these views up and down when the screen is tapped.
let page = document.getElementById("page");
let scn1 = document.getElementById("screen1");
let scn2 = document.getElementById("screen2");
page.onclick = function() {
vibration.start("bump");
scn1.groupTransform.translate.y = (scn1.groupTransform.translate.y === -200) ? 0 : -200;
scn2.groupTransform.translate.y = (scn2.groupTransform.translate.y === -200) ? 0 : -200;
}Ideally, I'd like for the elements to slide up but so far I haven't figured out how to accomplish that. Any thoughts on how I can make the translate happen over a period of say 0.3 seconds?
Best Answer05-02-2018 08:42
05-02-2018 08:42
let windowIsHidden = true;
function toggleWindow() {
if (windowIsHidden) {
// animate to show window
} else {
// animate to hide window
windowIsHidden = !windowIsHidden;
Best Answer05-02-2018 08:33
05-02-2018 08:33
I think I would setup the animation using svg, then trigger it from javascript.
Coordinate Animation
https://dev.fitbit.com/build/guides/user-interface/animations/#coordinate-animation
Triggering Animations from JavaScript
https://dev.fitbit.com/build/guides/user-interface/animations/#triggering-animations
Best Answer05-02-2018 08:37
05-02-2018 08:37
I looked at that the other day, but I couldn't seem to figure out how to toggle it like I want to. I need some kind of state to be able to move the views back and forth.
05-02-2018 08:42
} else {
Best Answer05-02-2018 12:04
05-02-2018 12:04
Thanks for the feedback @JonFitbit! I have a little bit more of an understanding of the animation class now, however, I am still having a bit of an issue here. Here's what I have so far.
index.gui
<svg id="page" pointer-events="visible">
<defs>
<symbol id="screen1">
[clock stuff]
<animate attributeName="y" begin="click" from="0" to="-200" dur="0.3"/>
<animate attributeName="y" begin="enable" from="-200" to="0" dur="0.3"/>
</symbol>
<symbol id="screen2">
[stats stuff]
<animate attributeName="y" begin="click" from="100" to="300" dur="0.3"/>
<animate attributeName="y" begin="enable" from="300" to="100" dur="0.3"/>
</symbol>
</defs>
<svg x="0" y="0" width="100%" height="100%">
<use id="screen1Instance" href="#screen1"/>
</svg>
<svg x="0" y="300" width="100%" height="100%" viewport-fill="red">
<use id="screen2Instance" href="#screen2"/>
</svg>
</svg>index.js
let scn1 = document.getElementById("screen1Instance");
let scn2 = document.getElementById("screen2Instance");
page.onclick = function toggleWindow() {
console.log("Opening Stats View...")
scn1.animate("click");
scn2.animate("enable");
} else {
console.log("Closing Stats view...")
scn1.animate("enable");
scn2.animate("click");
}This all works for toggling the clock view up and down, however, my stats view is no longer being displayed on the page. Not sure why.
Best Answer05-02-2018 12:26
05-02-2018 12:26
Nevermind, I solved my problem by using Layers.
