Announcing Fitbit OS SDK 4.1
SDK 4.1 adds a new API for calendar access, Always-on Display API, detecting a user's primary goal, and some rather useful enhancements to the Document API.
https://dev.fitbit.com/blog/2019-12-19-announcing-fitbit-os-sdk-4.1/
25 REPLIES 25
As soon as I add the permission "access_aod" I can install the app on the simulator but not on my Versa 2: "Error installing app" When I remove the new aod-permission it works again. Is there any trick to install my watchface on my watch with this new access_aod permission?
At this stage, Fitbit doesn't allow unapproved clockfaces/apps that use access_aod to run on physical devices until the app/clockface has been manually assessed to be non-damaging to the device.
Peter McLennan
Gondwana Software
No, Jemand, you may not make AoD apps. Did you not read the post at all?
Additionally, Fitbit, this message is for you: Instead of focusing on new additions, how about you ensure what you already have works? Your entire development process is a buggy mess.
@curxxx any specific issues you're referring to?
Since you asked, @JonFitbit, setting custom exercise names has never worked, and there doesn't seem to be a resolution in sight, even though clearly stated as possible in the documentation:
https://community.fitbit.com/t5/SDK-Development/Custom-exercise-name-and-GPS-data/m-p/3881462
I've had quite a few users request AoD and coming off developing watchfaces for Samsung smart devices I figured this would be a cinch. How foolish of me! After hacking the package.json and finally setting up something decent, I can't even test it on my actual Versa. Didn't I agree to something somewhere that says if I brick the watch it's my fault, you know, like almost every other developer license? This is beyond a joke and looking at the original date of this post it's been a long-running joke.
