09-08-2023 20:24
09-08-2023 20:24
In the Fitbit Gallery I noticed there are a few 3rd party clock faces/apps for Versa 4 and Sense 2. Does someone here know how to do it?
-What SDK and CLI versions to use
-What target names to use
-Should I need real devices to test? The current Fitbit OS simulator does not seem to support these devices.
09-09-2023 05:28
09-09-2023 05:28
@r.b-you are correct, but it hasn't been done by developers - it was a porting exercise done by Fitbit solely to try and make some non Fitbit clocks available and the process has now stopped. A marketing ploy, otherwise things would have been even bleaker for the new watches, with no user apps OR clocks.
These ported clocks are shown as "not optimized", they haven't been verified by the developers and cannot be corrected by developers if they do not work, they can only be removed from the Gallery. Some ported clocks cause the watches to crash.
Fitface clocks can still be made available because the shell has been tested but it's not free.
Furthermore the simple Fitbit Studio interface used to help anyone make clocks or apps has been removed. So it looks like the whole development process is being wound down for general users.
09-09-2023 01:48
09-09-2023 04:54
09-09-2023 04:54
Thank you, @Guy_ . But there are many 3rd party Versa 4 and Sense 2 clock faces published in Fitbit Gallery. I just checked its Best of 2022 section, and the first page had at least 5 3rd party clocks for Versa 4 and Sense 2. So, there must be some way to do it, because a number of developers seem to be already doing it.
09-09-2023 05:28
09-09-2023 05:28
09-09-2023 19:06
09-09-2023 19:06
Thanks, @Guy_ for the elaborate reply. I didn't know that it was porting by Fitbit, not developers.
Some more details from me also. After posting qustion here I checked @fitbit/sdk packages, and noticed that the Version "7.2.0-pre.0" has build targets of Sense 2 ("rhea") and Versa 4 ("hera"). I then modified package.json of my existing clock project (for Versa3 and sense) to use the above sdk version and build targets, did npm install and npx fitbit-builld, and the project was built without any errors. But I don't know whether the resulting .fba build file works on Versa 4 or Sense 2, because I currentlly have no way to test it. I will test after my current Versa 3 breaks (still working despite having cracks) and I buy a new one 😀😀😀.
09-09-2023 19:34
09-09-2023 19:34
@r.b - without the necessity source code changes it may not work right or even crash due to incompatibilities unless it is a very basic clock and without a simulator you can't test it.
Without the SDK documentation, if it ever comes, you won't know what those changes are either.
A better solution (from comments in the forums) might be to get another Versa 3 from the shops while still available and you can then use the features you have now which isn't the case on the newer watches.
You'll also still be able to continue to develop, test and publish stuff, if it's for non personal use.
09-09-2023 20:48
09-09-2023 20:48
Thank you, @Guy_ . Yes you are right. The SDK version I was mentioning might be an alpha or even pre-alpha one, and without any available documentation there is no point in trying to use it. I will take your suggestion and may buy a spare Versa 3 or Sense before it runs out of stock.
10-25-2024 07:58
10-25-2024 07:58
@Guy_ someone on r/fitbit is claiming they are making Sense 2 clock faces with fitface. Is that possible?
10-25-2024 08:37
