04-22-2020 17:23
04-22-2020 17:23
I'm struggling the change the "value" attribute which sets the scroll speed of the marquee. In my widgets.gui I have
<use value="1" id="marquee" href="#marquee-text" font-size="32" y="50%-40" width="100%"
height="80" fill="white" mode="1">
<rect width="100%" height="100%" fill="white" opacity="0.2" />
<set href="group/text" attributeName="text-buffer"
to="Hit the scramble button!" />
<set href="group/separator" attributeName="width" to="150" />
</use>and in my index.js I am trying to adjust the speed with button pushes.
const marquee = document.getElementById("marquee");
marquee.state = "enabled";
const increase_button = document.getElementById("increase");
increase_button.onactivate = function(evt) {
marquee.value = 25
console.log("Increase Button Pushed")
}the speed isn't changed when the button is pressed. The console outputs "Increase Button Pushed".When I try
console.log(marquee.value)It logs "undefined". I am very confused on how to change the speed of the scrolling of the marquee
