01-15-2019 16:47
01-15-2019 16:47
Utilizing the simulator has worked perfect up till today. Deleted Sim and reinstalled no luck. Mac OS operating system and computer.
1) Fitbit Studio build Project
2) Open Simulator
3) Select Versa Simulator
4) Run
App loads and runs fine, then...
1) Make a change in app using fitbit studio
2) Build or just go strait to run
3) The below error occurs and can not find a solution
(unable to paste screen shot for some reason)
Dang
Simulator failed to start: read ECONNRESET
Try Again
Try agin just sits there and spins and never does anything else. Only option is to exit simulator and start it up again to run changed app. As I previously stated nothing has changed, no updates nothing, worked up till today just fine.
Thanks...........
01-18-2019 12:56
01-18-2019 12:56
Is it just your project which causes this issue, or does the same happen with the default digital clock project?
Can you also collect logs and send them to me via a private message?
Logs:
OS X: ~/Library/Logs/Fitbit OS Simulator/log.log
Windows: %USERPROFILE%\AppData\Roaming\Fitbit OS Simulator\log.log
If the bug is reproducible, it's best to delete the log file then restart the simulator & repro the bug, to reduce the amount of noise in the log file.
If the bug relates to a particular app, send the Studio project export.
Thanks
01-16-2019 18:01
01-16-2019 18:01
Bump......
I cant be the only one having this issue?????????
01-17-2019 16:31
01-17-2019 16:31
So it has gone from bad to worse. Now Simulator opens and immediately closes. Uninstalled and reinstalled no help I also see in Dashboard under Manage Account Access that Fitbit Simulator has disappear. Can it get any worse?????
01-18-2019 05:23
01-18-2019 05:23
Doing nothing different, not even shutting the computer off, nothing, I can get to the login screen and back to the original problem. Only once can you run an app or clock face, then have to close simulator and reopen to run again.
01-18-2019 12:56
01-18-2019 12:56
Logs:
Thanks
01-18-2019 13:22
01-18-2019 13:22
Today I was able to narrow the problem down to the Heart Rate Monitor Code I am using. I have written a total of 10 clock faces / apps using the same code and worked fine up until the other day. I am going to play around with it and see if I can figure out why it no longer works and what I need to change in the current code. If not I will PM you as requested with logs etc....
01-20-2019 14:01
01-20-2019 14:01
Able to fix my code (still not sure why it use to work) to display the heart rate.
To reiterate: Error in Heart Rate code will cause Fitbit Simulator to crash on second time running it. No error during build or Build Output. On first load you just don't have any info displayed in simulator for Heart Rate. Removing the line: hrm.start(); simulator does not crash. I wish I could tell you the exact problem with my code but I just started over from scratch.
02-05-2020 15:21
02-05-2020 15:21
Same problem. No solutions that I saw in various places work. Here is my log:
[2020-02-05 17:49:49.705] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 17:49:53.706] [warn] 10 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 17:49:55.596] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 17:49:58.398] [warn] 9 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 17:50:00.402] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 17:50:02.902] [warn] 8 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 17:50:05.905] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 17:50:08.405] [warn] 7 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 17:50:12.409] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 17:50:14.516] [info] appsim stdout: [I][17:49:50.296][] Starting breakpad client - reporting to \\.\pipe\Fitbit OS Simulator Crash Service
Congratulations! Your Higgs has been selected to take part in an exciting
new opportunity called _Appmgr_RemoveAllApps().
This may take a few minutes. Thank you for your patience.
Completion Percentage: 1% Completion Percentage: 2% Completion Percentage: 3% Completion Percentage: 4% Completion Percentage: 5% Completion Percentage: 6% Completion Percentage: 7% Completion Percentage: 8% Completion Percentage: 9% Completion Percentage: 10% Completion Percentage: 11% Completion Percentage: 12% Completion Percentage: 13% Completion Percentage: 14% Completion Percentage: 15% Completion Percentage: 16% Completion Percentage: 17% Completion Percentage: 18% Completion Percentage: 19% Completion Percentage: 20% Completion Percentage: 21% Completion Percentage: 22% Completion Percentage: 23% Completion Percentage: 24% Completion Percentage: 25% Completion Percentage: 26% Completion Percentage: 27% Completion Percentage: 28% Completion Percentage: 29% Completion Percentage: 30% Completion Percentage: 31% Completion Percentage: 32% Completion Percentage: 33% Completion Percentage: 34% Completion Percentage: 35% Completion Percentage: 36% Completion Percentage: 37% Completion Percentage: 38% Completion Percentage: 39% Completion Percentage: 40% Completion Percentage: 41% Completion Percentage: 42% Completion Percentage: 43% Completion Percentage: 44% Completion Percentage: 45% Completion Percentage: 46% Completion Percentage: 47% Completion Percentage: 48% Completion Percentage: 49% Completion Percentage: 50% Completion Percentage: 51% Completion Percentage: 52% Completion Percentage: 53% Completion Percentage: 54% Completion Percentage: 55% Completion Percentage: 56% Completion Percentage: 57% Completion Percentage: 58% Completion Percentage: 59% Completion Percentage: 60% Completion Percentage: 61% Completion Percentage: 62% Completion Percentage: 63% Completion Percentage: 64% Completion Percentage: 65% Completion Percentage: 66% Completion Percentage: 67% Completion Percentage: 68% Completion Percentage: 69% Completion Percentage: 70% Completion Percentage: 71% Completion Percentage: 72% Completion Percentage: 73% Completion Percentage: 74% Completion Percentage: 75% Completion Percentage: 76% Completion Percentage: 77% Completion Percentage: 78% Completion Percentage: 79% Completion Percentage: 80% Completion Percentage: 81% Completion Percentage: 82% Completion Percentage: 83% Completion Percentage: 84% Completion Percentage: 85% Completion Percentage: 86% Completion Percentage: 87% Completion Percentage: 88% Completion Percentage: 89% Completion Percentage: 90% Completion Percentage: 91% Completion Percentage: 92% Completion Percentage: 93% Completion Percentage: 94% Completion Percentage: 95% Completion Percentage: 96% Completion Percentage: 97% Completion Percentage: 98% Completion Percentage: 99% Completion Percentage: 100% Completion Percentage: 101% (Higgs always gives 111%) Completion Percentage: 102% (Higgs always gives 111%) Completion Percentage: 103% (Higgs always gives 111%) Completion Percentage: 104% (Higgs always gives 111%) Completion Percentage: 105% (Higgs always gives 111%) Completion Percentage: 106% (Higgs always gives 111%) Completion Percentage: 107% (Higgs always gives 111%) Completion Percentage: 108% (Higgs always gives 111%) Completion Percentage: 109% (Higgs always gives 111%) Completion Percentage: 110% (Higgs always gives 111%) Completion Percentage: 111% (Higgs always gives 111%) _Appmgr_RemoveAllApps() is complete.
[E][17:50:13.823][] Fb_UserAlarms_Read: KV entry for alarm info not found!
[E][17:50:13.823][] Fb_UserAlarms_Read: Any Alarms have been purged.
[D][17:50:13.828][] Scheduler starting dispatch time: 1580943013828
[2020-02-05 17:50:14.785] [info] appsim exit code: 1 (signal null)
[2020-02-05 17:50:14.909] [warn] 6 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 17:50:19.914] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 17:50:22.413] [warn] 5 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 17:50:28.417] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 17:50:30.917] [warn] 4 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 17:50:37.921] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 17:50:40.422] [warn] 3 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 17:50:48.500] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 17:50:51.000] [warn] 2 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 17:51:00.008] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 17:51:02.507] [warn] 1 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 17:51:12.512] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 17:51:15.012] [error] Simulator hosts failed to start: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:08:19.216] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:08:20.098] [info] appsim stdout: [I][18:08:19.443][] Starting breakpad client - reporting to \\.\pipe\Fitbit OS Simulator Crash Service
[E][18:08:19.585][] Fb_UserAlarms_Read: KV entry for alarm info not found!
[E][18:08:19.585][] Fb_UserAlarms_Read: Any Alarms have been purged.
[D][18:08:19.587][] Scheduler starting dispatch time: 1580944099587
[2020-02-05 18:08:20.156] [info] appsim exit code: 1 (signal null)
[2020-02-05 18:08:21.717] [warn] 10 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:08:22.719] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:08:25.221] [warn] 9 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:08:27.223] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:08:29.724] [warn] 8 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:08:32.725] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:08:35.226] [warn] 7 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:08:39.231] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:08:41.731] [warn] 6 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:08:46.735] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:08:49.234] [warn] 5 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:08:55.247] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:08:57.746] [warn] 4 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:09:04.751] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:09:07.252] [warn] 3 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:09:15.256] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:09:17.756] [warn] 2 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:09:26.763] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:09:29.264] [warn] 1 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:09:39.270] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:09:41.771] [error] Simulator hosts failed to start: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:14:42.056] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:14:42.674] [info] appsim stdout: [I][18:14:42.275][] Starting breakpad client - reporting to \\.\pipe\Fitbit OS Simulator Crash Service
[E][18:14:42.302][] Fb_UserAlarms_Read: KV entry for alarm info not found!
[E][18:14:42.302][] Fb_UserAlarms_Read: Any Alarms have been purged.
[D][18:14:42.304][] Scheduler starting dispatch time: 1580944482304
[2020-02-05 18:14:42.731] [info] appsim exit code: 1 (signal null)
[2020-02-05 18:14:44.556] [warn] 10 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:14:45.559] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:14:48.060] [warn] 9 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:14:50.065] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:14:52.565] [warn] 8 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:14:55.567] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:14:58.067] [warn] 7 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:15:02.080] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:15:04.581] [warn] 6 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:15:09.595] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:15:12.094] [warn] 5 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:15:18.122] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:15:20.619] [warn] 4 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:15:27.642] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:15:30.143] [warn] 3 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:15:38.152] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:15:40.653] [warn] 2 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:15:49.661] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:15:52.160] [warn] 1 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:16:02.183] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:16:04.683] [error] Simulator hosts failed to start: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:16:08.265] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:16:08.613] [info] appsim stdout: [I][18:16:08.354][] Starting breakpad client - reporting to \\.\pipe\Fitbit OS Simulator Crash Service
[E][18:16:08.387][] Fb_UserAlarms_Read: KV entry for alarm info not found!
[E][18:16:08.387][] Fb_UserAlarms_Read: Any Alarms have been purged.
[D][18:16:08.390][] Scheduler starting dispatch time: 1580944568390
[2020-02-05 18:16:08.638] [info] appsim exit code: 1 (signal null)
[2020-02-05 18:16:10.765] [warn] 10 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:16:11.767] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:16:14.270] [warn] 9 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:16:16.273] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:16:18.773] [warn] 8 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:16:21.775] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:16:24.276] [warn] 7 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:16:28.279] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:16:30.780] [warn] 6 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:16:35.783] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:16:38.282] [warn] 5 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:16:44.288] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:16:46.788] [warn] 4 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:16:53.801] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:16:56.302] [warn] 3 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:17:04.377] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:17:06.879] [warn] 2 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:17:15.897] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:17:18.396] [warn] 1 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:17:28.403] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:17:30.904] [error] Simulator hosts failed to start: MethodCallTimeout: No response received for RPC call to 'initialize'
