12-30-2019 11:59
12-30-2019 11:59
Hi Fitbit Community,
I'm making an app using the multi view svg functionality. I followed this example:
https://github.com/Fitbit/sdk-multi-view
I added Kpay and I'm getting the problem that the index.js only navigate to the main view the very first time is executed, otherwise is stuck on index.gui. I tried to keep the KPay code as easy as possible, this is the code in app/index.js:
https://gist.github.com/LazaroIbanez/a0c9a322cd5548e2eafa34c5817c50ec
Does this happen to you before?
Thanks on advance,
Regards,
Lazaro
