05-20-2020 05:29 - edited 05-20-2020 05:30
Hello,
I am sorry to ask about such a NOOBish topic, but I have been struggling with ]setters in the SDK. I am making a grade calculator, and I have no problem with imports, and the actual pre-made calculator is working well. However, I want to allow users to change the grade range and it is not working. It seems the get and set keywords do not work (I get the error "expected a comma after set"), and if I put it in a class, it seems the compiler cannot read export functions.
I am fully aware that this is my own ignorance of JavaScript, however, none of the solutions I have found for node.js or regular JavaScript seem to work for me.
Here is what I have currently. This is not the actual app, I made a new one just to test getters and setters. This is the full code for that.
in index.js...
* Entry point for the watch app
import * as calculation from "../common/Calculation.js"
console.log("App code started");
calculation.Calculator.calculate(3)
In my calculation.js
class Calculator{
export function calculate(i) {
newNumber = 0;
var newNumber = 5+i;
this.newNumber = newNumber;
/*function getNumber(){
return newNumber;
var newNumber = getNumber();
console.log(`${newNumber}`);
let cal = new Calculator();
Thanks for reading.
05-20-2020 21:54
05-20-2020 21:54
Not really. There are heaps of different ways to do classes/objects in JS (even in ES5.1). You could try getting a setter to work in the same file as the calling code (ie, don't try import/export initially). Once you've got that going, refactor.
Here's a little something that probably won't help. There are probably better ways to do it.
05-20-2020 13:22
05-20-2020 13:22
Setters can work. You just have to be careful to use ES5.1 dialect on the watch.
Some examples I've used:
set log(val) {_log = val; _maxValue = 0}
Object.defineProperty(Gauge.prototype, 'units', {
set: function set(val) {
this._unitsEl.text = val
05-20-2020 19:31
05-20-2020 19:31
Thank you. That helps. I will try it.
05-20-2020 21:16
05-20-2020 21:16
So, I tried for a while, and no matter what I did, I cannot get either of those to work with an export function that is called from index.js do you have any hints?
05-20-2020 21:54
05-20-2020 21:54
05-21-2020 05:08
05-21-2020 05:08
Actually,
That is exactly what I was looking for. My confusion was how to utilize the objects between files. I could get it working in one document, but when trying to move the object between, it would fail. This framework helps and models the way I was trying to utilize. Thank you. It will take me a bit, but I will share the solution (based on your model) when I am done.
05-21-2020 11:27 - edited 05-21-2020 16:07
It works. Here is the code I am using.
In index.js
import {Calculator} from "../common/Calculation.js"
//Construct the calculator
const myCalculator = new Calculator('myCalculator')
//Set the variable value
myCalculator.calculate = 20
In Calculation.js
//create the export function
export function Calculator(_input) {
//pass the value
this._input = _input
//create the setter
Object.defineProperty(Calculator.prototype, 'calculate', {
if (this._calculate === val) return
this._calculate = val
this._calculation()
//Do something with the data.
Calculator.prototype._calculation = function() {
let input = this._calculate;
let output = 5*input
console.log(`The raw number is... ${output},`)
My errors before were plentiful, but the biggest were...
Thank you again for all of your help.
05-22-2020 21:27
05-22-2020 21:27
Apologies for the kibitz...
Objects work, functions as variables work, modular programming works. They really did make this very complete, and I do like good OOP.
That said...
We're programming inside a very small box, objects are huge, and passing variables by reference in javascript is hinky.
If you intend to do anything complex, a single monolithic file with simple functions and variables takes a lot less memory.
05-23-2020 08:17
05-23-2020 08:17
Thank you for the info. It is helpful. I am new to javascript, and I am certainly feeling its hinkiness. As far as system resources go, is there a way to see, or any hints as to where to look, to find the resources your application is using? I love how the Arduino IDE says "Your app is X size and uses Y amount of memory." Is there anything similar?
05-23-2020 10:32
05-23-2020 10:32
@LekoFraggle wrote:Thank you for the info. It is helpful. I am new to javascript, and I am certainly feeling its hinkiness. As far as system resources go, is there a way to see, or any hints as to where to look, to find the resources your application is using? I love how the Arduino IDE says "Your app is X size and uses Y amount of memory." Is there anything similar?
05-23-2020 19:29
05-23-2020 19:29
Arduino is extremely cool. You can make almost anything (electronic) with an Arduino Nano.
Hey, if you want a good tutorial on javascript you could try the W3 school:
It's very thorough.
05-23-2020 20:48
05-23-2020 20:48
Thank you for your help. I will look into Wc3. My confusion is the different versions of javascript. I think going through their tutorials from beginning to end may help. Yes, I have a few Arduino Nanos, and they are incredible. Your comments are helping significantly. My app is close to finished 🙂 with no memory problems currently.
