06-11-2018 10:19 - edited 06-11-2018 10:21
I frequently have two Studio windows open, it would be very helpful if the project titles were visible somewhere in the Studio interface while the projects were open to keep them straight. It seems this could be easily incorporated either into the header bar, or as a top-level branch in the file-nav pane.
Thanks!
06-11-2018 13:43
06-11-2018 13:43
If your browser window is wide enough, the project name appears at the bottom right.
Best Answer06-11-2018 13:43
06-11-2018 13:43
