10-21-2020 14:51
10-21-2020 14:51
I have had the Vesa 2 for a few months now. After the 4.2 update, the settings app icon on the watch itself disappeared.
Everytime I open the application it reboots the device.
Is there a way to trigger a recovery mode, reinstall the OS, or downgrade to a new OS in order to reinstate the settings app features?
Best Answer10-21-2020 22:15
10-21-2020 22:15
You could try this in the phone app
tap profile picture, top left
tap device picture, middle left
tap on apps
Check if there is a Settings app in My Apps, it may require an update
If its not there, or anyway, go to All Apps, search for Settings and add it.
Might help.
