05-06-2019 20:45 - edited 05-07-2019 09:28
Hi there,
I am playing around with the heart rate monitor app for my Fitbit Ionic, which shows heart rate every second. I want to make so if heart rate goes below a certain level, vibrate is turned on as an alert. I want this to be done every 3minutes. So the HR is monitored every second BUT the alert is monitored every 3minutes and when I press any of the side buttons on my ionic, the alert vibration should stop.
right now I have it as if the heart rate goes below 60, the vibrate is turned on but I don't know how to attach it to a button that will shut it off for 3minutes. Any help would be appreciated. Thanx in advance
if (hrm.heartRate < 60)
vibration.start("ring");
document.onkeypress = function(e)
console.log("Key pressed: " + e.key);
vibration.stop()
Best Answer05-09-2019 03:01
05-09-2019 03:01
Sorry, looks like it was slightly wrong. It's using modulo https://stackoverflow.com/questions/16505559/how-can-i-use-modulo-operator-in-javascript
That should have been
(today.getMinutes() % 3) === 0
You can see it in action here: https://jsfiddle.net/xz7a0gdf/3/
Best Answer05-07-2019 10:14 - edited 05-07-2019 10:18
Something like:
let timer;
function heartAlert() {
document.onkeypress = function(e) {
vibration.stop();
clearInterval(timer);
// inside tick event?
if (hrm.heartRate < 60 && today.getMinutes() % 3 && !timer) {
timer = setInterval(heartAlert, 1000); // every second
Best Answer05-08-2019 18:56
05-08-2019 18:56
could you please explain how today.getMinutes() % 3 part of the code works?
05-09-2019 03:01
