07-04-2021 06:42
07-04-2021 06:42
Hi,
I am running a simple app writing HR data into a file and enqueueing to the companion. It is running on clockface so the app does not get turned off. However at some point, I keep getting the log below from companion side and peer connection is not established. "fitbit app was opened on device; companion will no longer be unloaded; App closed on device, unloading companion in 3 seconds".
Reason why I can say the peer connection is not established is that I set Fitbit to sync with companion only if the messaging socket is OPEN.
Can anyone help with this issue?
Best Answer08-05-2021 19:29
08-05-2021 19:29
Hello @strmng! To save device battery, it unloads the companion, and when you reopen it it starts the companion side again.
If this answer works please mark this post as a Best Answer. ~ K.K Designs
