06-07-2018 13:26
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-07-2018 13:26
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I know others have had similar problems with the combo-button and events not working but I haven't found a solution yet. I'm using the combo-button-lower-right button on an Ionic. An onclick event is triggered when I touch the screen over the button, this is working as expected. However, if I click the lower right button, I expect the onkeypress event to be triggered but it's not. The onkeypress event worked for the LR button until I added the combo-button. Seems like the combo-button is causing the issue.
index.gui snippet <use id="btn-br" href="#combo-button-lower-right" fill="fb-peach"> <set href="combo-button-icon" attributeName="href" to="pin.png"/> <set href="combo-button-icon-press" attributeName="href" to="pin-press.png"/> <set href="combo-button-stroke" attributeName="display" to="inline"/> </use>
index.js snippet let mainScreen = document.getElementById( "main-screen" ); let btnBR = mainScreen.getElementById("btn-br"); btnBR.enabled = true; btnBR.onactivate = function(evt) { console.log("BOTTOM RIGHT ONACTIVATE!"); } btnBR.onclick = function(evt) { console.log("BOTTOM RIGHT ON CLICK!"); } // Physical Key events document.onkeypress = function(evt) { console.log("ONKEYPRESS " + evt.key); evt.preventDefault(); if ( evt.key === "up" ) { console.log("UP"); } else if (evt.key === "down") { console.log("DOWN"); } else if (evt.key === "back") { console.log("BACK"); } }
Accepted Solutions
06-14-2018 07:32
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-14-2018 07:32
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
This is not going to help much, but I had the exact same problem. The combo buttons override the onkeypress when on the right side. The combo button even overrides the onkeypress when the button is not visible.
What I needed up doing was just creating my own button by using and image and circle and setting the x and y so that it shows in the corner ( I'd suggest using percentages something like x="100%-50" ).
06-14-2018 07:32
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-14-2018 07:32
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
