01-30-2024
23:04
06:54
CrisVillaFitbit
01-30-2024
23:04
06:54
CrisVillaFitbit
The battery on my sense 2 is draining at a ridiculous speed. I'm lucky to get 3 days. Bluetooth only turned on when I'm driving, which is max 2 hours a day. Any ideas?
Moderator edit: edited title to clarity
Hi there, @Stimpy_Goat welcome to the community.
Thanks for letting me know about this situation with the battery of your Sense 2.
I was able to check in the system about this and found that you have to turn off the always-on display setting, since this is causing the battery to be drained faster.
I recommend you to check this article, there are some tips that can help you also.
Best AnswerThank you so much.
Welcome back, @Stimpy_Goat, you're very welcome!
Let me know if the steps I suggested you forsooth helped you, so this post can be seen by other users and they'll know what to do in these kinds of situations.
