06-14-2023
07:57
11:46
LizzyFitbit
06-14-2023
07:57
11:46
LizzyFitbit
Just moved to a Sense 2 and the alarm vibration is to soft. I've read the manual, I know how to set the alarm, and I know how to change the vibration level to the highest of the two settings. Is there also a volume setting or is the alarm always silent with only a vibration function? In other words can the alarm beep or buzz as well as vibration?
Best Answer06-14-2023 08:59 - edited 06-16-2023 06:14
Hi @Sailingman53 - unfortunately there is only vibration for alarms and timers. People have asked for sounds.
Audible alarms and notifications on Sense series, Versa 3 and Versa 4
The vibration is quite weak and gets even weaker as the battery level falls.
