05-28-2024 07:32
05-28-2024 07:32
I've been trying to change the lap length from 25 to 50 but all the instructions (swipe up once you e started the exercise in the watch app) don't work. I thought previously I'd done it on the phone app but maybe I'm wrong about that. I've done this in the past, but am stuck. Can this still be changed?
Best Answer05-28-2024 08:57 - edited 05-30-2024 04:03
Hello @SunsetRunner and welcome to the Community. Actually, don't start the exercise on the Sense 2. Short press the button > open the Exercise app, then choose swim. Swipe up on the tiny "^" on the bottom of the screen. Swipe up and look for Pool length. Tap on it to change your distance. After you spin the spring screen to get to 50, tap to confirm. If you ever need it, you select meters or yards there, too.
You can't change a setting once you start an exercise.
Laurie | Maryland
Best Answer05-28-2024 07:33
05-28-2024 07:33
I figured out how to switch from meters to yards, but not the length of the pool itself.
Laurie | Maryland
Best Answer05-28-2024 10:04
05-28-2024 10:04
