I have just had to get a new Sense 2 when my Sense died.
I am having difficulty setting exercise options (lap notify, length etc). When I swipe up to set the options it only stays on the screen for about 1 second before starting the exercise and then the options cannot be set.
Another issue is when an alarm goes off the screen flashes off and on which makes turning off the alarm quite random.
Hopefully Fitbit read this and fix these issues.
Hi @MuzDownUnder - you need to press the button briefly and select Exercise and the one you want, then scroll up to do settings. Using a shortcut starts the exercise immediately.
For the alarm try holding the button for 10 seconds till it vibrates and the logo appears and wait for it to start and see if that clears the flashing issue.
