11-06-2025 13:40
11-06-2025 13:40
I was trying to log my food today and it will not show any food when I put an item in. It will also not show anything in the database when I scan and I know those items are in there. Please help. I have a sense 2 and an apple
11-15-2025 16:18
11-15-2025 16:18
I don't have pending updates for the Fitbit app. I've uninstalled and reinstalled the app and restarted my phone multiple times. The issue persists.
Best Answer11-16-2025 11:55
11-16-2025 11:55
I have the same issue in that I can't create custom foods any more.
Please can you fix this as I use it quite a lot for calorie tracking?
Thanks
11-16-2025 13:15
11-16-2025 13:15
My app is updated to the latest, I've uninstalled/reinstalled and powered on/off multiple times but am still unable to enter custom foods
11-17-2025 09:37
11-17-2025 09:37
Mines the same, been like it for over a week.
Best Answer11-17-2025 09:48
11-17-2025 09:48
Hi @Jd123454321! It's great to have you here!
Thank you for letting us know that your Sense 2 is not customizing your food logs, we are aware of this inconvenience and are working to find a solution as soon as possible.
11-17-2025 09:49
11-17-2025 09:49
11-21-2025 03:38
11-21-2025 03:38
Two weeks later and it's still not fixed for me. I have installed every update that's been put out so far.
Google Pixel 9 Pro XL
Fitbit Version 4.56
Best Answer11-24-2025 12:46
11-24-2025 12:46
Hi @nerdpower13! Welcome back to the Community!
Thank you for letting us know the details about this inconvenience.
According to several users and our team, this issue should already be resolved. If you are still experiencing it, please try turning your phone off and on again.
Best Answer11-24-2025 13:41 - edited 11-24-2025 14:15
Hi everybody! Thank you for your messages and feedback.
The issue with the serving drop down will be discussed in another thread to avoid further confusion.
If you are having that issue, I suggest you follow this other thread.
unable to add custom foods - no serving drop down menu.
Best Answer11-24-2025 13:45
11-24-2025 13:45
Thanks for letting us know.
Best Answer11-24-2025 15:06
11-24-2025 15:06
11-24-2025 15:09
11-24-2025 15:09
That serving size drop down is not working for some of us.
Best Answer11-25-2025 09:55
11-25-2025 09:55
I can finally search the food database now but they broke the "Save Food" button in custom entries! There's no update available and it's been AWHILE now, this is nuts. For the first time in about 8 years I'm considering just changing watches and starting over with something that is accurate and just using an app that is known to work.
Best Answer11-25-2025 09:58
11-25-2025 09:58
Are you able to create and save custom food? The logging works, but the SAVE button in the custom foods is broken for me 😞
Best AnswerWednesday
Wednesday
I finally got mine to work, by logging out of the Fitbit app, clearing the cache and force stopping it. After that I was able to add custom foods once again. Hope this helps.
Wednesday
Wednesday
Hi everybody! Thank you for your messages and feedback. We've released a new app update (v4.57) Please make sure that you all have this installed.
After the update, please try turning your phone off/on and see if the issue with the food log (save button) still appears and or if got solved for you.
Please comment below and let us know how it goes, so that we can inform our team about the results.
Wednesday
Wednesday
The update has not shown up on Google Play yet @JuanFitbit. If it does, I'll have the phone restarted and see if that will help.
Wednesday
Mine is working now. I updated and it still wasn't showing up so I did what a different user suggested and logged out, cleared my cache, then logged back in and it works now.
Wednesday
Wednesday
Wednesday
That's what I said. It will show up at some point.
