HR test to check accuracy
ANSWERED
How do I know if the Fitbit is logging my heart rate correctly?
Is it too much or too low?
1 BEST ANSWER
Accepted Solutions
Hello @Lilabradford73 the easiest is to compare with a finger reader.
Or manually check it.
  • Looking at the second hand of a watch
  • 2 fingers on the inside of the wrist.
  • Count your pulses for 15 seconds.
  • Multiply the count by 4.
  • Answer should be close to what fitbit says.
How to determine your heart rate
2 REPLIES 2
@Lilabradford73 Welcome to this great community!
@Rich_Laue Thanks a lot for sharing your knowledge with us.
I believe your recommendation will be incredibly helpful to others facing similar situations. That's why I decided to mark it as the Best Answer.
Thank you again for your willingness to help!
