12-12-2022 16:29
12-12-2022 16:29
For those of you who are having problems with erratic HR readings on your Sense 2, you might be interested in my experience: I have been getting shorted a bunch on Zone Minutes, as well as noticing erratic HR readings. It is only a week old. Customer Service told me today that I have a defective device, and they will replace it.
Perhaps a bad batch got out and they know it? I don't know, but thought it would be worth a try. Passing this along for others who have expressed concerns here.
Best Answer12-12-2022 16:42
12-12-2022 16:42
Might want to see the results before advertising the cure.
Best Answer12-12-2022 16:52
12-12-2022 16:52
May or may not be a cure, but I decided nothing ventured, nothing gained. They did replace my Inspire 2 when it went crazy...then the band broke off of the replacement. At least it was working! I can't afford to buy another just yet, so I will try to make this one work. If it never does, I will just switch to a non-Google product next time. In the mean time...
