12-06-2022
22:44
16:26
LizzyFitbit
12-06-2022
22:44
16:26
LizzyFitbit
I believe there is continuous ecg monitoring is that correct? But how do I do a manual ECG scan? When I select the app on the watch "ECG" it says "Can't find phone" at the top, and to open the Discover tab on the phone. Why can't it find my phone? It's able to sync correctly and the "find my phone" app works fine
12-08-2022 01:00
12-08-2022 01:00
Hi Ronald, I managed to sort this out! I tried holding down the side button to do a hard reset, and for some reason it fixed it! Strange it worked with that but not a factory reset? Anyway, all is well now. Thanks for your time
12-07-2022 08:24 - edited 12-07-2022 08:25
Hi@sbzero, I'm not sure what the issue is here but to start I think this topic can be helpful What is the Fitbit ECG app?
IIt covers how it works, installing the app (if needed).
12-07-2022 09:17
12-07-2022 09:17
Hi Ronald, thanks. I believe this was already installed by default according to the app. If I press the left button the ECG app will come up as an option, however it will say "Can't find phone" once pressed. Not sure what's with that.
12-07-2022 11:16 - edited 12-07-2022 12:03
I'm curious what you see when you follow these steps (copied from the manual):
1. With your Fitbit device nearby, from the Today tab in the Fitbit app, tap your profile picture then your device image.
2. Tap Gallery then Apps tab.
3. In the list of apps, tap ECG
If you click on the app you will see an option named Settings or Permissions. Check if all options are set to yes.
Otherwise I would suggest to uninstall the ECG app, restart the Sense 2 and do a fresh install.
Best Answer12-07-2022 19:52
12-07-2022 19:52
Something interesting here. Under "Apps" ECG is not listed, however on the "Sense 2" page it is listed under "My Apps". When I click it there's only an "Uninstall" option. When I push it, it says "Unable to install". Another thing too is that that page says my battery is full even though it's not. This is after a full sync.
12-07-2022 21:08
12-07-2022 21:08
Hey @sbzero thanks for trying this and sharing your findings. I must say that I'm only left with removing the Fitbit app from your phone, and go for a 'factory reset' on the Sense 2 to do a fresh setup.
I really hope someone else pops in with a less drastic solution 😊
Best Answer12-07-2022 22:51
12-07-2022 22:51
Thanks Ronald.
Before I go ahead with this could I just please confirm, you are also running a Sense 2 on the latest firmware update, and are able to manually launch the ECG app from within the watch fine?
12-07-2022 22:58 - edited 12-07-2022 22:59
Yes for me it all works well. I have checked for the versions I'm using now:
Sense 2 firmware: 60.20001.184.52
Fitbit app version: 3.71
ECG app version: 1.184.52 (Nov. 1)
Hope this helps
Best Answer12-07-2022 23:57
12-07-2022 23:57
Hi Ronald,
I completely uninstall the Fitbit app on my phone, and also did a factory reset on the watch. Strangely enough after setting everything up again, it remembered my Watch Face, which wasn't the default one?
Also the same problem again, the ECG app doesn't appear under "Apps" but only under the "My Apps" section (where it says it's installed). Again when attempting to launch the app on the phone, things seem to be going fine until the same "Can't find phone" message appears.
I'm curious about something else: On the Fitbit phone app it displays the battery correctly, but when clicking my profile and "Sense 2", it always says "Battery Full" even though its at 75%. This is after a successful sync as well. Are you also running into this issue, or does it display the correct battery when you push "Sense 2" on the profile?
Best Answer12-08-2022 00:27
12-08-2022 00:27
Hi @sbzero, weird something this drastic didn't work out. My battery stats are the same on the app home screen as on my device, but now you mention it the device tap in my Android app does also state 'full'.
So this is the same at both sides.
It would be great if @LizzyFitbit would be able to help us.
Best Answer12-08-2022 01:00
12-08-2022 01:00
12-08-2022 01:47 - edited 12-08-2022 01:56
Great to hear this! Just a basic reset did the trick? Wonderful, I'll keep this in mind next time I'm troubleshooting with someone ('did you turn it off and on again' 😉).
12-19-2022 17:38
12-19-2022 17:38
Hi there, @sbzero. @RonaldM Thanks for your amazing help!
@sbzero That's great news! Thanks for the details and the time taken while troubleshooting your Sense 2. I'm glad you sorted this out and I'll mark your post as the Best Answer to help other members experiencing similar issues.
In case you have some spare time, I’d like to invite you to visit our Health & Wellness board where you can share your stories, make new friends and start your own topics. Happy stepping!
07-16-2023 12:46
07-16-2023 12:46
I can't find the original conversation I was viewing but, hopefully, this info may help others having trouble doing a manual ECG reading on the Sense 2. After my 1st attempt was unsuccessful, I searched everywhere for troubleshooting advice. I rebooted my phone & my Sense 2, unpaired it, deleted it from the Fitbit app, added it again. My next attempt in placing my fingers on the designated corners resulted in no progress. I decided to try lifting those corners of my screen protector (which I had immediately applied upon unboxing my new device), placed my fingers again on those corners & the reading progressed perfectly. I would never have guessed that a film that thin could prevent the device from sensing my fingertip placement.
07-21-2023 09:28
07-21-2023 09:28
Welcome to the community, @PACUnurseSuz.
Thanks for joining this thread and sharing the steps that worked for you. That's a great tip and I'm sure your post will be of great help for other members!
By the way, let me invite you to visit our Health & Wellness board where you can make new friends and start your own topics. Have a nice weekend ahead.
