10-12-2022
09:59
11:18
LizzyFitbit
10-12-2022
09:59
11:18
LizzyFitbit
I had a Sense then it stopped charging so I bought the Sense 2 in February. Now this one won't charge!! It is very frustrating. Not sure I am keen on the magnetic charger. Anyone else having a similar issue(s)?
10-12-2022 19:25
10-12-2022 19:25
Same issue with my sense, 4 pin charger, device is dead no way to revive, three different chargers, no luck. I would take mag charge any day over these custom chargers
10-12-2022 19:30
10-12-2022 19:30
i had same issues with mine also, but i figured the issues some months back
Best Answer10-13-2022 10:37
10-13-2022 10:37
My new fitbit sense 2 won't charge. What did you figure out about that?
Best Answer10-14-2022 02:18
10-14-2022 02:18
I have exactly the same problem.
Let me know if you find a solution
Best Answer10-14-2022 12:50
10-14-2022 12:50
I ordered a new charger- I'll let you know if that works. It looks like one of the four pins on the charger is bent?
10-14-2022 15:24
10-14-2022 15:24
Hi everyone, and welcome to our new members.
@ACW22 Thanks for the update, I'm glad you got a new charging cable. Once you receive it, try charging your watch and let me know how it goes.
@LauraScooby and @Bobby54 Thanks for letting me know about your Sense 2. I went ahead to check your details and I noticed you already have a case created with our Support team. Please keep an open communication with them as I'm sure they'll continue helping you.
@paul.mcgrail and @michealmarsh Thanks for sharing your comments. Take in mind this thread is related to the Sense 2. In case you have a different device, I'd recommend sharing your comments in their respective board as this will help us keep the forums organized. In the meantime, let this help article.
Best Answer10-16-2022 00:28
10-16-2022 00:28
Hi
I'm having the same issue here with sense 2 not charging. If this can't be resolved by Fitbit quiclky/easily and with no further expense to me, then the watch is going back in the post and a refund will be expected.
10-16-2022 07:11
10-16-2022 07:11
10-17-2022 07:16
10-17-2022 07:16
I have to factory reset my fitbit to get it to charge. I don't know what to do really.
10-18-2022
12:18
06:50
10-18-2022
12:18
06:50
Hi there, @LauraScooby and @ANameNotUsedYet. @SHAYo Welcome on board.
@SHAYo and @LauraScooby Thanks for your efforts, and I'm sorry for the experience that you've had with your Sense 2. I went ahead to check your details and it seems our Support team is already helping you with this matter. Your case is in good hands, so please keep an open communication with them.
@ANameNotUsedYet Thanks for joining this thread and letting us know what steps you've tried so far. I'm sorry the issue persists and just to confirm, have you also tried the troubleshooting described here? If not, please give it a try and let me know how it goes so I can continue helping you.
Best Answer10-22-2022 20:56
10-22-2022 20:56
So, it only charges after a factory reset. My procedure for charging is:
1.) Factory Reset
2.) Immediately plug into power.
If I disconnect from power and try to reconnect it, it will no longer charge.
If I pair with phone, it won't charge when I need it to. I usually wait until 35%.
And yes I've tried all of the the recommended troubleshooting steps.
10-28-2022
19:50
06:51
10-28-2022
19:50
06:51
Hi there, @ANameNotUsedYet.
Thanks for getting back with the requested information. I'm sorry your Sense 2 doesn't charge correctly and because we've exhausted the troubleshooting steps, I've requested a case on your behalf so you can receive further assistance from our Support team. They'll get in touch with you via email, so please keep an eye on your inbox.
