Red X on Sense 2
Hi, as above , sense 2 totally died, battery started to drain really quickly and then had the usual red x a couple of times etc. tried factory reset but now it’s not coming on at all, tried holding button for 10 seconds but just get the logo for a few seconds and then nothing…..?
watch is just over 18 months old.
Moderator edit - updated subject for clarity
3 REPLIES 3
Hi @Mattimoo ! Warm welcome to the forums !
I appreciate your message, and I'm sorry to hear your Sense 2 totally died, battery started to drain really quick, and then you saw a red x a couple of times, and when you tried some troubleshooting you just got the logo for a few seconds and then nothing.
I understand your concern about this situation, and I'll be more than glad to suggest you some steps.
Please, in the Fitbit app, try to sync your device :
  • With your Fitbit device nearby, open the Fitbit app.
  • From the Today tab, press and hold on the screen and pull down until you encounter a progress bar at the top of the screen.
    Release your finger and wait for the progress bar to fill. (You should be able to see an update banner here).
    If the update banner doesn't pop up:
  • Tap the device's icon MarioSFitbit_0-1739973050281.png > Your device > Gallery. (You should be able to see a message about some installations).
    Finally, try to restart your device, as shown here : How do I restart my Fitbit device?
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
Hi,
Many thanks for replying
Have tried to restart but just getting :cross_mark:, tried pairing with my phone but obviously can’t see what the four digit code is to pair it as the devise won’t start/ see the screen?
Sent from my iPhone
Hi @Mattimoo ! Welcome back to the Community !
I appreciate a lot your message and all your troubleshooting efforts. I'm really sorry to hear that you already tried the proposed steps with no results.
Since you have tried the troubleshooting procedures and considering the issues with your Sense 2, I recommend you to follow the link in order to contact support, as they have more tools to find your options. What can we help with?
