02-16-2025
17:07
10:17
FatimaFitbit
02-16-2025
17:07
10:17
FatimaFitbit
For a few days, maybe a week now, my sense 2 screen would just go blank and I would not be able to turn it on. Eventually the fitbit logo would come on after pressing or holding down the side button but it usually didn't go away until I put it on the charger. When the home screen came on eventually, the time would be off and I had to manually sync it via the app. I tried to restart my sense 2 and now it won't even turn on at all. If I hold the side button for about 2 sec, the fitbit logo comes up then disappears. If I hold the button longer (for 5-10 sec), the fitbit logo will come up but the screen flashes between green/black then eventually a big red X comes up.
Hi there @Stripes924!
A warm welcome to the Fitbit Community!
Thank you so much for informing us about this situation and for all your efforts.
Have you already tried to reset your Sense 2? If not, please try to do the following (make sure you sync your Sense 2 with the Fitbit app first):
Yes I tried this. I got the screen with the fitbit logo with circle around it then the next screen is a smaller fitbit logo with a progress bar at about 3/4 way filled. Then the screen shuts off after a second or 2 then nothing happens and the screen goes black again.
Thank you for your answer and for all your efforts.
Since you have tried the steps and your Sense 2 still doesn't work, I need more information from you, which is best shared privately. I am sharing a link to a form for you to fill out here.
This form is for you only, so let me know when you have completed it.
Thank you. I just completed the form.
