02-19-2025
15:15
18:59
ManuFitbit
02-19-2025
15:15
18:59
ManuFitbit
Hello!
There are tons of topics about this issue and Fitbit says “Hurray you solved it” but it never seems like the problem is solved… I have tried so many different way to solve this, all the forums, everything. It doesn’t just “automatically reconnect”… It just plain doesn’t work…. So a useful answer or solution would be GREAT!
Moderator edit: clarified subject.
Best Answer02-19-2025 18:57 - edited 02-19-2025 18:58
Welcome to the forums @Greenaway.
Thank you for providing the information and the details regarding this difficulty with your Sense 2 and for trying to fix it on your own.
If you didn’t set up on-wrist calls when you connected your Fitbit device to your account, from the Today tab in the Fitbit app on your phone, tap Devices > your device image > On Wrist Calls. Please follow the instructions below to set up on-wrist calls:
02-19-2025 19:34
02-19-2025 19:34
Best Answer02-20-2025 15:24
02-20-2025 15:24
Thanks for the response @Greenaway.
Sorry to know that you are still experiencing this same situation.
Please, can you confirm that the following steps are all done to get the wrist calls in your device?
If you continue to have issues, try the following troubleshooting steps:
Note that your Fitbit device's controls or calls might be listed as “Not Connected” in the list of Bluetooth devices on your phone. When you receive a phone call, the controls automatically reconnect. This feature requires more frequent charging.
