Hi, my SP02 is trending upwards and is out of my normal range. But can't really find anyway that explains the risk of impact of this.....any pointers, I have searched several sources but end up at the same few articles,,#.
Best AnswerIn terms of SpO2, the higher the better really. You'd want to be as close to 100% as possible. As for why yours has changed, it's impossible for us to say. Although I wouldn't think it's a bad thing.
If you are concerned it's really best to speak to your Doctor.
