12-28-2022 06:33
12-28-2022 06:33
I’ve tried everything that in feeds but still every night get this reading? Any suggestions?
Best Answer12-31-2022 08:13
12-31-2022 08:13
How long have you had the device? I think you need to wear it a certain amount of nights so that it can pick up your sleep and SP02 patterns.
one cruise ship at a time!
Best Answer01-01-2023 18:38
01-01-2023 18:38
I have faced the same issue. Perhaps coincidental but whenever I use a SPO2 watch face it records data on the first night with that watch face and then stops recoding data completely so data is not available on the watch or in the app. I then change watch face and all subsequent SPO2 is recorded and available in the app.
Best Answer01-02-2023 06:59
01-02-2023 06:59
Hi @Debbrown.
Can you confirm that you have installed the spO2 app from the app gallery?
If it's already installed I would recommend uninstalling it and then installing it again. Hopefully that will sort things out for you.
