03-20-2023 10:10
03-20-2023 10:10
Whenever I’m exercising my sense 2 only shows current exercise info. Is there a way I can look to see what time it is while I’m exercising? I can’t seem to get out of the exercise screen unless I stop it and exit.
Best Answer03-20-2023 10:30 - edited 03-20-2023 10:31
Hello @SunsetRunner and welcome to the Community. The exercise screen has a top, middle and bottom stat. The current time is one of the middle stats that you can view by tapping/swiping. The Sense 2 exercise screen is very customizable. For example, short press the button and open your Exercise app. Select Run. Swipe up on the tiny "^" at the bottom of the screen. Keep Swiping until you get to the Show Stats option. You will see that the top stat is distance and the bottom stat is elapsed time. You can change the top or the bottom to the current time, if you want. It's especially handy to customize the middle stat. You can remove some of the stats you don't want to see.
Do this for every shortcut you use.
Laurie | Maryland
Laurie | Maryland
03-20-2023 15:28
03-20-2023 15:28
Wow! Thanks so much👏🏽👏🏽 I never noticed that🤷🏻:female_sign:
