02-24-2025
12:11
11:12
FatimaFitbit
02-24-2025
12:11
11:12
FatimaFitbit
Hi my calandar notifications though on are not feeding through to my Sense 2. Texts and calls are working ok but not Calendar. All three are selected in the app
I have checked settings and all appear ok. They have worked occasionally but not 99% of the time
Hi @anncjones - if your watch isn't syncing when you get the calendar notification and you acknowledge it on the phone it will no longer appear on the watch.
To check, when you get a notification, sync the watch with the Fitbit App, to make sure it's connected before taking any action with the notification on the phone.
Hi Guy
Thanks for taking the time to reply but I don’t understand what you are saying. All my notifications, texts, calls and calendar came through on my old Versa 2 since upgrading to the Sense 2 I am not getting notifications from my calendar. My Fitbit must be connected in order to get the text and calls notifications? Apologies if I’m being thick!
@anncjones- thanks, there is no agenda app on a Sense 2 but if you have any notifications that appear on the status bar of the phone these should come to watch also, if they have been enabled and the watch is connected and not in Sleep or Do not disturb mode [hence turning off the icons may be an issue]. In short it works differently than the Versa 2.
See more here
How do I get notifications from my phone on my Fitbit device?
Hi I have never used the agenda app previously. The notifications are working on my phone and neither do not disturb nor sleep modes are activated.
