10-21-2025 10:16
10-21-2025 10:16
I have owned several Fitbit (for iOS), so I know how it is supposed to work. But on my Sense 2, when I try to start a walk, I go to Exercise and tap on Walk (whether I do it through All or not), the screen says Exercise and then goes blank and then back to the Home Screen.
Best Answer10-21-2025 20:52
10-21-2025 21:03
10-21-2025 21:03
10-21-2025 21:14
10-21-2025 21:27
10-21-2025 21:27
10-21-2025 22:46
10-21-2025 22:46
@Bkford - it's possible the watch has a fault, especially if it got wet, and has other issues or gets hot when charging, or there is just a software corruption.
If it is really annoying a factory reset may cure it, but you will have to set it up again after.
It is a good idea to make a note of the names of any clocks and any special watch or settings you use before the reset, and note if you live in the EEA you may not be able to reinstall everything without using a VPN connection on your phone.
Best Answer10-22-2025 07:40
10-22-2025 07:40
10-22-2025 08:11
10-22-2025 08:28
