01-26-2024
08:58
14:56
ManuFitbit
01-26-2024
08:58
14:56
ManuFitbit
Every day, my watch shows several thousand steps taken around noon even though I'm sitting at my desk and not moving. These steps are denoted on my computer in green lines. Any ideas as to what might be causing this and how to fix ?
Moderator edit: clarified subject.
Best Answer01-26-2024 09:05
01-26-2024 09:05
Hi @redroc.
You mention it happens whilst sitting at your desk. Do you happen to be typing at the time? These movements and vibrations can unfortunately be mistaken for steps.
01-26-2024 11:18
01-26-2024 11:18
Best Answer01-26-2024 14:28 - edited 01-26-2024 14:28
Welcome to the community forums @redroc.
Thank you for taking the time to share this experience with us. I'm sorry to know the inconvenience.
Do you have Phone on the Fitbit app installed? This feature allows you to record basic stats such as steps using your phone's sensors. That being said, if there was a fan or something vibrating nearby, that might be the reason why you receive an incorrect amount of steps.
Assuming this is correct, I'd recommend removing it by doing the following:
Thanks for helping @N8teGee
