03-13-2024
18:08
08:04
ManuFitbit
03-13-2024
18:08
08:04
ManuFitbit
I need help figuring out how to get my exercise days to show up in my activity. Steps are showing up as well as intensity but the last two days that I did vigorously work out on my treadmill, nothing is documented! I want my app to work. March 13,2024; I attaching because this issue is new to me.
Moderator edit: clarified subject.
Best Answer03-14-2024 07:56
03-14-2024 07:56
A warm welcome to the forums @Leothesungoddes.
Thank you for taking the time to share the situation with your Sense 2.
I'd recommend you try to perform the following steps on the Fitbit app:
Best Answer03-14-2024 14:07
03-14-2024 14:07
Syncing failing to work correctly is a well known long-running issue that Google/Fitbit seems to have no intention of fixing. If I had known how buggy syncing is with this watch I would have bought something else. All they'll tell you is to reboot your watch, reboot your phone, unpair, re-pair, etc. It should just farking work but it doesn't.
