03-05-2024
13:04
11:54
AndreaFitbit
03-05-2024
13:04
11:54
AndreaFitbit
By Sense 2 died earlier today and is not charging I have two charging cables and have tried both I have cleaned the pins etc and tried various charging ports on two different laptops and different wall sockets too but to no avail
Moderator Edit: Formatting.
03-05-2024 18:49
03-05-2024 18:49
Hi @Oonagh40 - what caused the watch to stop? Did it get wet? Did you make a change or just forget to charge it. If the latter see instructions in How to check charge cable - Sense 2/Versa 4 won't charge, won't start or blank screen
It is possible the cables are both faulty.
However try holding the button for a full 10 seconds and after 30 seconds try and sync with the Fitbit App which if successful would indicate a display failure rather than a charging problem.
03-05-2024 18:49
03-05-2024 18:49
03-31-2024 19:07
03-31-2024 19:07
Same here!
Best Answer04-01-2024 03:07
04-01-2024 03:07
Fitbit support were very helpful and as my Sense was eligible for a replacement unit I received a new one within a few days.
04-04-2024 11:53
04-04-2024 11:53
Welcome to the Fitbit Community, @Oonagh40, @suarezal. I'm sorry to hear that your Sense 2 is not charging. @Oonagh40, thank you for mentioning all the steps that you have followed and I'm glad to hear that you received a replacement.
@suarezal, could you please let us know if you have already tried the steps that @Guy_ mentioned on his post?
@Guy_, thank you for your help as always.
