03-22-2025 10:00 - edited 03-22-2025 10:08
Hi
Can anyone help.
The main reason I buy Fitbit smartwatches rather than trackers is the built in GPS feature. I replaced my trusty Versa with a Sense 2 recently and 2nd hike in succession the GPS kept failing to connect, vibrating as it did and then failed completely. My Versa never had this problem. I'm at the stage where I'm ready to send it back for a refund and buy an Appple Watch! Before I do please can anyone help. I've been a loyal Fitbit since 2015.
The app is up to date, and it was fully charged.
Best Answer03-22-2025 18:09
03-22-2025 18:09
Hi @anncjones. Welcome back to the community.
Thank you for providing the information with me regarding this difficulty experienced with Sense 2. Sorry to know about it.
All devices with GPS sensors require a direct path to GPS satellites to calculate location. A weak GPS signal might affect the accuracy of your route and other activity data. Your device uses your step count to calculate distance until it finds a signal, so the total distance calculated for a workout may be slightly less accurate when GPS isn't available for the entire time. With that being said, please make sure of the following:
If you continue to experience the same behavior and your GPS is getting disconnected, make sure to try following the steps listed in this article to complete a restart, as this has been useful for other users experiencing something similar.
Best Answer03-23-2025 03:52
03-23-2025 03:52
Hi ManuFitbit
Thank you for the reply. Both hikes were in open sky situations, and I've checked the app is set to always, however this shouldn't be an issue with connected GPS. What do you mean by “adjust how you wear the tracker when you want to use GPS”. I've been using Fitbit smartwatches for 9 years now and this is the first time I've had this issue so I am feeling it is the Sense 2
Best Answer03-25-2025 20:54
03-25-2025 20:54
Maybe have the app open and have it sync properly with the Sense 2 before your start your hike?
My old Blaze never lost a connected GPS signal, while the Sense 2 is flaky, especially with the new connected GPS feature. If it loses connected GPS connection, sometimes it never revert back to its internal GPS sensor.
Best Answer03-26-2025 00:16
03-26-2025 00:16
Thank you Phatbitzr
I will do that. I'm disappointed in the Sense 2 and looks like I'm not the only one.
Best Answer03-28-2025 10:24
03-28-2025 10:24
I've had a Sense 2 since last May and sometime in December, the GPS stopped working accurately. I've rebooted, ran in different locations and barely any of my runs are accurate. This was a run from last week in DC. There's no way I was over the river and back. I've had the Fitbit Versa, the Fitbit Ionic and have never had GPS problems before.
