I’ve owned the sense 2 for two days. I’ve worn it for two days. It hasn’t collected ANY sleep data for two days. Is this the sort of thing that eventually starts working or should I expect that I have purchased a device that simply won’t track any sleep data. I wear a tracking ring and it collects the sleep data without any difficulty, including my sleep over the last two days. The Garmin I was using, which I have replaced with the sense 2, tracked sleep data consistently. Am I missing something here? I’ll be returning the sense to if it can’t track sleep.
What I’ve done so far: night 1, sleep sensitivity was set to normal. He didn’t track anything. Night 2, hey Siri, I turned off the watch and turned it back on. I insured it was fully charged. I had sleep sensitivity set to sensitive. It didn’t track anything.
Best AnswerI have it since yesterday, and it recorded my sleep with no issue last night. Try to factory reset it.
Best AnswerI’ve reset it. I talked with Fitbit support and they had me remove the sense 2 from the app and re add it. Sleep sensitivity is set to sensitive and I’ll test it tonight.
Best Answer@Squashdog Have you had any success with your sleep data?? Everything I try doesn't help and I haven't gotten sleep stages for 8 nights now.
