08-22-2024
06:53
10:08
ManuFitbit
08-22-2024
06:53
10:08
ManuFitbit
For a few days now I have problems with the Start Exercise tile on the Sense2. As soon as I swipe it, the Sense2 is immediately reboot. Solved!
Moderator edit: clarified subject.
08-23-2024 09:54
08-23-2024 09:54
It’s solved, see:
Here are some steps you can perform to resolve your issue:
We would like to ask you to perform the factory reset via the button, to do this follow the steps below:
After the reset, you will need to add back the apps you had added, and pair your Fitbit according to the steps you can find here: How do I set up my Fitbit device?
Unsynchronized data will also be permanently deleted.
08-23-2024 07:22
08-23-2024 07:22
Welcome back to the community, @SunsetRunner.
Thanks for letting me know about this situation in regards to the exercise tile, I can imagine the impact of this.
Can you let me know if this is still happening, please? If so, comment on what you did to improve the situation. In case this continues, try changing the clock face of your Sense 2 and restarting it.
Best Answer08-23-2024 09:54
08-23-2024 09:54
It’s solved, see:
08-23-2024
11:11
15:57
ManuFitbit
08-23-2024
11:11
15:57
ManuFitbit
Hi, I am having the same problem! Swiping doesn’t bring up my exercises tiles, it reboots! I did everything said in the above thread and nothing?
I have just changed my clock face, nothing!
08-26-2024 07:27
08-26-2024 07:27
Welcome back, @SunsetRunner! And thank you for letting me know the steps that worked for you to get this improved, I truly appreciate your efforts!
And welcome to the community, @Hepk.
Can you confirm if you tried the step that @SunsetRunner mentioned, please?
Best Answer08-26-2024 09:01
08-26-2024 09:01
I’m having the same problem and there doesn’t seem to be a firmware update available in Canada. I updated Fitbit today and it’s not showing the pink update.
Best Answer08-26-2024 15:47
08-26-2024 15:47
Hi,
thank you for your reply, I just did another full reset and nothing!
so annoying!
08-26-2024 15:48
08-26-2024 15:48
08-26-2024 15:49
08-26-2024 15:49
08-26-2024 16:02
08-26-2024 16:02
It was the newest firmware update that did this in Canada (last week sometime). That was the update that was released weeks ago in the US. I think they are just getting to fixing it in the US so who knows when it will get to Canada. 🙄
