05-02-2024 15:36
05-02-2024 15:36
The screen in my sense 2 went dim. It was working fine a few hours ago. I tried changing the clock im the app and it did not change on the sense 2. I will try charging it when i get home from work. Any other ideas
Best Answer05-02-2024 21:12
05-02-2024 21:39
05-02-2024 21:39
I did not turn on sleep mode. I pulled down the menu and I can not even tell what icon is what.
Best Answer05-02-2024 21:44
05-02-2024 21:54
05-02-2024 21:54
It did not work. When i pull to get the settings, do not disturb all those icons do not show up.
Best Answer05-02-2024 22:04
05-02-2024 22:07
05-02-2024 22:07
@Mgeller - in case you have an older watch swipe the watch face to the right to get to Quick Settings, otherwise it's pull down on the watch face.
Try also holding the watch button for 10 seconds till it blanks or vibrates and wait for the logo to appear and for it to start.
Best Answer05-02-2024 22:27
05-02-2024 22:27
Thank you for your help. Holding it until the icon worked along with changing the clock face
