05-08-2023
13:24
16:26
ManuFitbit
05-08-2023
13:24
16:26
ManuFitbit
Hi trying to load spo2 app and seems to not want to it shows as loading but that’s all that happens be thankful for any advice 😊
Moderator edit: clarified subject.
21:52
16:52
05-08-2023
21:52
16:52
Hi @Manxlass - loading watch faces can sometimes be problematic if the watch is not syncing well.
Go back to where you can sync the watch and try again.
You may need to start by restarting the watch and possibly logout of the app, swipe off the active window and in Android clear the storage cache and force stop it and then restart the phone.
Login again and wait for any pair, link or Fixit prompts and sync then try again.
Also this watch face will only gives the one SpO2 value for the whole day and doesn't change, you may want to consider a different face which provides more useful information.
If you swipe the watch face right and tap you can still check the SpO2 level on the watch.
