03-16-2025
17:48
16:26
ManuFitbit
03-16-2025
17:48
16:26
ManuFitbit
Recently I read, on techradar, about a mandatory update to Fitbit versa 3 and Sense 1. But that update messed up the battery life (from 6 days to one day) of those devices.
I'm about to buy Sense 2 and out of curiosity I went to Fitbit community forums and found out some Sense 2 users were also complaining about the short battery life after the update.
Is this problem is also affecting Sense 2?
Moderator edit: clarified subject.
03-16-2025 20:09 - edited 03-19-2025 05:07
Hi @jone4646 - the forced battery update was for the Versa 3 and sense 1 only.
Some watches of all types can have battery problems for loads of different reasons but a Sense 2 firmware update has not been released recently or in the same time frame, so is unlikely to be the cause.
03-17-2025 14:18 - edited 03-17-2025 14:18
Lol. The 1st post was a copy of a post I made yesterday on Reddit. Copy+paste.
Anyway. I didn't have much feedback on Reddit and was planning to post here.
What I found in this community were people, on another post, that had a normal battery life, on February 2025. After an update they said they received, the battery barely lasts one day. That post is still on the 1st page of sense 2 community. If my battery is fine, I receive un update and now my battery is now not ok, the culprit of course is the update.
I would like to see more feedback from Sense 2 users, because I plan to buy Sense 2. And it's on hold. I refuse to buy something that I have to charge more than 1 time a week.
03-17-2025 14:37
03-17-2025 14:37
I have a fitbit sense 2 and the update definitely affected it. I will definitely not be getting another fitbit in the future. I have had this less than a year and i now have to replace it. I am not happy at all.
03-21-2025 09:57
03-21-2025 09:57
If you are able to hold off, do so. If you are looking to buy something now, I personally would not get this. I absolutely LOVED my sense 2, however after the update I can no longer use my watch. I have tried many different attempts to get it to work. It won't turn on now. I have had previous versions of Fitbit before Google took over, and they all lasted MUCH longer for less of the investment. I came to rely on the data, and now no longer have that data. It is very sad, and seems like it was not a good investment for the short amount of time it lasted for me.
03-21-2025 13:22
03-21-2025 13:22
Has anyone reached out to Fitbit regarding this issue to see if they plan to do something to remedy it?
Best Answer03-29-2025 01:32
03-29-2025 01:32
I had an update in February. It wasn't a firmware update. I know this because I was waiting for the next firmware update. I saw an update and thought it was the upcoming update. After this update my battery life dropped by 20%.
Support says there is no update. I Can't prove it
Best Answer03-29-2025 01:42
03-29-2025 05:13
03-29-2025 05:13
it was after update still 210.26
Got my Update 214.24 some days ago
Best Answer03-29-2025 05:25
03-29-2025 05:25
@RolandDa- the first one listed seems to be the least troublesome. People similar to you are now receiving the last one.
If your watch is working fine installing a firmware update is probably not going to go as smoothly as hoped. And if your watch has a problem a firmware update is likely to make matters worse.
