07-23-2024 08:28
07-23-2024 08:28
Best Answer07-24-2024 13:54
07-24-2024 13:54
Welcome to the community! Thank you for your messages and efforts.
Our team is aware of the situation and is working on a solution to it.
Many users have now confirmed that they were able to fix it by entering the stride length themselves. It's worth a try until our team has worked on the solution.
You can find instructions for this here:Can I change my stride length in my Fitbit account?
Please follow this thread where all updates will be posted. Distance appears as 0 after sync
Best Answer07-23-2024 11:18
07-23-2024 11:18
Hi there Caragold I posted with this exact issue a couple of days ago, Fitbit will I'm sure eventually fix this issue but if you can't wait I have a temporary fix in this thread
07-24-2024 13:54
Best Answer08-14-2024 00:17
08-14-2024 00:17
Same issue here! My Sense 2 stopped tracking distance yesterday (I walked 15000 steps but only 4 km are registered..) moreover, Ilthe mindfulness sessions are not registered on the phone app anymore. I tried to uninstall/reinstall the app and only 1 session of the week appeared…
Best Answer08-21-2024 12:44
08-21-2024 12:44
My Sense 2 stopped tracking distance when i walk (I start the walk exercise manually in the device) . Moreover when i run ,it shows (i start the run exercise manually)distance but the map either appears incorrect or not at all. I called the support but not much help from the team.
Best Answer08-21-2024 12:45
08-21-2024 12:45
Ot doesn't work, My Sense 2 stopped tracking distance when i walk (I start the walk exercise manually in the device) . Moreover when i run ,it shows (i start the run exercise manually)distance but the map either appears incorrect or not at all. I called the support but not much help from the team.
