04-08-2023
11:48
12:49
JuanFitbit
04-08-2023
11:48
12:49
JuanFitbit
Multiple chargers, but won`t charge
Best Answer04-08-2023 18:15
04-08-2023 18:15
Hi @jackdee - things to verify
if never been able to charge, check carefully back of watch, sometimes there is a tiny piece of plastic covering contact holes.
Try pressing the button and check for vibration, it may also start.
Try double tapping and swipe the watch face in any direction, if you get a display change clock face in the phone app.
Change power source and maje sure terminals on the back of the watch are clean.
Hold the button for at least 10 seconds till it vibrates and the logo appears.
Check in the Fitbit App if the watch is syncing, if so , there can be a screen failure.
See also How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
