10-16-2022
03:54
18:35
LizzyFitbit
10-16-2022
03:54
18:35
LizzyFitbit
I’ve owned many Fitbits, most recently the Ionic (for 6 years), loved it, loved how it recorded all of my sleep stages.
I decided to upgrade my watch and and stay in the Fitbit family, so I bought a Sense 2. However, it doesn’t record the sleep stages and give me a sleep number like my Ionic did for years. I read into this and read I needed to be a Premium member, so, I became a Premium member…but, my Sense 2 still is not recording my sleep stages. (Very frustrating) I’ve read so much, tried different things and still cannot resolve the problem and get the watch to record my sleep stages and give me a sleep number. (About ready to return my watch)
10-16-2022 05:24 - edited 10-16-2022 05:30
Hi Paul, I never used a Ionic myself but since owning a Versa and now the Sense 2 receiving Sleep Stages/Score is a real struggle. And a premium subscription isn't needed. First I'll share the usual solutions mentioned here and by Fitbit support: General troubleshooting Sleep Score .
But personally I have the most 'luck' by placing my Sense 2 two fingers away from my wrist bone. It's trail and error with the Fitbit wrist strap not to tight/loose. And my latest discovery is making sure my skin is not too dry (rubbing in some skin lotion on my wrist every morning). And now I get mostly 5 out of 7 days my Sleep Score.
Best Answer10-16-2022 05:24 - edited 10-16-2022 05:30
Best Answer10-16-2022 06:11
10-16-2022 06:11
Thank you for your quick reply Ron, at this point, I’ll try anything…I’d consider myself technically Davy, but, this thing has really challenged me.
I never had any problems with my Ionic…my skin is typically normal, I’ll try to move it up and I read turning it towards me might help too. (I’ll try to make it not too tight or too loose too).
Thank you -
Paul
10-17-2022 02:45
10-17-2022 02:45
Hi Ron - very frustrating…moved my watch toward me, moved it away from my wrist, still didn’t work…perhaps looser? It was already pretty loose…but, I’ll try that tonight
10-17-2022 03:51
10-17-2022 03:51
Hey Paul, thank you for the update. I totally understand your feelings. I can only say again I wear it two fingers away from my wrist bone, loose but the wristband isn't able to 'move' to easily. And again the skin ointment (wishful thinking I guess), is one of my 'tricks'.
Best Answer10-20-2022 04:46
10-20-2022 04:46
Ronald -
Since moving my Sense 2 up my arm (toward my elbow) and keeping it a tiny bit looser...I've had 4 out of 4 nights of it working. Thank you for the advice...(I had no need to put any lotion or ointment on)
Thank you -
Paul
10-20-2022 04:57
10-20-2022 04:57
Amazing Paul, thank you for the update!
Best Answer10-26-2022 06:31
10-26-2022 06:31
@Paulsaint how far up your arm are you wearing it at night? I'm having the same issue. No stages the last 6 nights, even though I didn't change anything and was getting the stages for 5 nights before that. (I've only had the watch less than a month). I'm getting really frustrated as I know you were. I tried Ron's tip of lotion and higher up my arm last night, but still didn't work. I'm just wondering how far up I should try??
