05-05-2023
09:31
11:02
05-05-2023
09:31
11:02
please help me: fitbit sense 2 does not show incoming call contacts. Is there any way to fix it?
Best Answer05-05-2023 11:06 - edited 05-26-2023 12:13
Hi there, @chindung. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the issue with your Sense 2.
As a first approach, please check that your notifications have been setup correctly. For more information, see How do I get notifications from my phone on my Fitbit device?
If the above has been checked and all the notifications settings are correct, I'd like you to please confirm if you have enabled the Fitbit app permissions under Settings of your Android device. If you've done that, please try going to the phone Settings > Apps > Fitbit > Permissions and toggle off "Contacts", then restart your phone and toggle "Contacts" back on.
