03-22-2023
07:48
05:40
03-22-2023
07:48
05:40
The time I go to bed is off by an hour. I've change the bedtime time. Restarted the watch. What can I do.
Best Answer03-23-2023 00:16
03-23-2023 00:16
Hi @Checha - most likely the summer time change has not been registered properly on your watch and phone.
In the Fitbit App, click profile photo and App settings and toggle the automatic time zone Off-On, logout of the app and swipe off the active window and in Android clear the storage cache and force stop it.
Restart the phone and the watch. Login again and wait for any pair or link prompts and sync.
03-23-2023 05:14
03-23-2023 05:14
@Checha I looked at your public profile and saw that your asked a similar question in the Luxe forum. Can you please clarify your question? Are you sating that your Fitbit misses the start time when you go to sleep? Or is it something else?
Laurie | Maryland
03-23-2023 17:51
03-23-2023 17:51
Above the today tab, tap your profile picture, then tap "App Settings" then check and change your time zone, and more.
Best Answer03-26-2023 05:29
03-26-2023 05:29
Hi
I had a Luxe before the Sense 2 and it was doing the same thing before the time change. I did everything people said change my bedtime hour, restart the fitbit, uninstalled the app. And a few times in a month it register my bedtime ahead by an hour.
Best Answer03-26-2023 05:31
03-26-2023 05:31
Hi
Both fitbits are doing it, it register the hour of the bedtime ahead by an hour. I've restarted it, uninstalled the app.
