The Stopwatch function is really difficult to start and reset, and it got worse after the recent update.
I use the stopwatch a lot (for cooking). When I open the app (using the hold-button function), I have to scroll down to be able to tap on the stopwatch rather than use the countdown function. There should be an option to open the stopwatch directly like in the old models, or at least don't force me to scroll down- I feel like there is enough spece on the screen to have both coutndown and stopwatch availble without scrolling.
The second issue is that resetting the stopwatch is really hard- there seems to be only a tiny space on the arrow that actually resets the time. There is no reason why the fucntional area can't be wider as there isn't anything elase I'd be doing nearby on the screen!
Best Answer@Maliw I also use timers and the stopwatch a lot. This is how I made it easier for me. There is a Timers tile, one of the screens that you see when you swipe left/right on the screen, meaning you don't need to push the button. You can customize the tile order and I put my Timers tile to be the first one I see when I swipe left. If you tap on the three dots, you go to the screen where you can choose between a timer and the stopwatch. I agree with your comment about having both on the screen at the same time. You do need to swipe up slightly, then you can start the stopwatch. I think the text would be completely unreadable if Fitbit tried to put them both on the same screen.
I'm sorry, but I got the firmware update and I can't reproduce your issue with the reset arrow.
Laurie | Maryland
Best AnswerSorry if I wasn't being clear- I have customzied my watch to go to the countdown/stopwatch tile/app when I hold the button down. The issue I am having is that from there it is annoying to hav to scroll down to start the stopwatch. There should be an option to customize having the stopwatch come up as a first option, or even right away as I remember it being on the Versa watch.
Best Answer@Maliw I’m sorry that I misread your post. Fitbit changes navigation from model to model. The best way to give feedback is by posting in the Product Feedback forum.
Laurie | Maryland
