03-21-2023 13:54
03-21-2023 13:54
Ever since getting the Sense 2, I've seen that the time displayed in the iPhone FitBit app that corresponds to time zone is not my local time, but in UTC time.
For example, I just got a response notification (about noon local time AKDT). But when I go into the app, the corresponding response shows that the notification is for 8:32 - 8:37pm which is UTC time. And the daily boundaries used by the app is based on this UTC time. The Sense 2 device itself uses local time to display the response chart and the previous 2-hour time period. Oddly, the FitBit app's "Last 2 hr" chart also uses the local time (but not the "Today" chart).
Am I missing something obvious? A setting that I need to change? Or is this how this feature is supposed to work (I think it is odd), or a bug?
Best Answer03-21-2023 14:01
03-21-2023 14:01
Above the today tab, tap your profile picture, then go down and click “App Settings” and and you can change your time zone from there, then make sure to sync your device.
03-21-2023 14:09
03-21-2023 14:09
Yes, that works. But... Why shouldn't the app display these items in local time when timezone setting is set to "automatic"? Everything else in the app functions that way. It seems inconsistent.
Best Answer03-22-2023 16:16
03-22-2023 16:16
Maybe it mistook your location...
