03-03-2023 02:45
03-03-2023 02:45
The stress management is no longer working. used to have at least a couple of notifications a day but have had nothing for the last 5 days. I think the watch did an update,, it crashed, reset and since then the stress management is not working.
Best Answer03-03-2023 16:13
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
03-03-2023 16:13
Tap "Stress Management" tile in the Fibit App. Tap cog wheel in upper right corner. Is "Body Response" switch toggled "On"?
Best Answer03-07-2023 01:19
03-07-2023 01:19
Yes it's switched on. I have toggled it a few times.to see if that makes a difference and it doesn't. It used to work well but since the crash / update it has not picked up any responses at all.
03-07-2023 13:19
03-07-2023 13:19
I have the same problem after reset/update. Contacted support, however, still no solution.
