05-01-2024 08:58
05-01-2024 08:58
Does any clock face for Sense 2 or Versa 4 show actual MINUTES walked (lightning bolt symbol) - (NOT zone minutes - I don't use the zone minutes)? I just want to know when my set time for walking is up without having to sync my Fitbit on my phone or tablet and then check it on the computer. I'm having trouble seeing some of the info on the small screen on my Charge 5, so I want to go back to a larger screen. Thanks for any help with this.
Best Answer05-01-2024 19:35
05-01-2024 19:35
Hi @LynneLee - Fitbit switched to Active Zone Minutes but if you just want to see active minutes, try SimpleClockPro which displays AZM by default but tap heart rate to briefly check Active minutes in its place.
05-01-2024 19:35
05-01-2024 19:35
05-02-2024 07:28
05-02-2024 07:28
Thank you! It seems to be just what I need. 😊
05-07-2024 02:46
05-07-2024 02:46
SimpleClockPro is indeed an impressive clock face with lots of extra features (estimated time to charge, charge history, 5 levels of brightness, flashlight...) Is there any chance that Fitbit would buy it in order to keep it available after june 2024?
05-07-2024 03:43
05-07-2024 04:34
05-07-2024 04:34
I know. I did not ask the question for me. I believe it is the watch face that should be delivered as the standard one on any Sense 2 sold.
