01-19-2024 18:37
01-19-2024 18:37
on the watch, exercise options used to exist. after the update i can only select between run, walk or bike.
i cannot select the other exercises option as it does not open anything now. i primarily use the weightlifting or treadmill option while working out, and before those were both available options to select. now after the update they are no longer there.
I can manually add the workout on the app, but that defeats the purpose of the watch and ease of use that existed until the update a few days ago.
is there a known issue with this, or a work around i can due to fix this problem?
I have tried shutting the watch down, and uninstalling the exercise option from teh watch in the app, neither were useful in solving the issue.
thank you.
Best Answer01-19-2024 21:21
01-19-2024 22:08
01-19-2024 22:08
yes. this is why i can only see run, walk and bike as options to select on the watch now.
the other options are other exercises and history.
other exercises would be the option before that showed the other exercises modes that were available (pilates, yoga, swim, weightlifting, powerlifting, treadmill, etc)
history is for opening on the app, to manually add on the app with, but has no relevance to what i want to continue using my sense 2 for.
Best Answer01-19-2024 23:01
01-21-2024 17:02
01-21-2024 17:02
are you talking about turning the watch off, then back on? if so, yes.
What I am asking is why aren't any other exercises appearing in the exercise option on the watch now, after the update. there is no way to open any other option as they no longer exist. you can't open anything else in the watch itself.
Best Answer01-21-2024 21:26
