04-24-2024 19:42
04-24-2024 19:42
How do I get 250 steps from 11 PM to 12 AM? So I can get my 14 hours. I don't want to start until 10 AM. It will not let me choose 12 AM or 11:59.
Best Answer04-24-2024 21:54
04-24-2024 21:54
Hi @Chelle-07 - there are some things you can't do with the Fitbit App Move hours but you may find a sophisticated clock face which can, such as SimpleClockPro which caters for night shift working and besides has multiple reminders per hour and an all day steps history by hour. See the clock face description and documentation link.
Best Answer04-24-2024 23:15
04-24-2024 23:15
Best Answer04-24-2024 23:20
04-24-2024 23:20
@Chelle-07 - did you change it on the watch settings, on the clock face click heart rate twice and follow the instructions given in the documentation?
Best Answer04-24-2024 23:31
04-24-2024 23:31
Best Answer04-24-2024 23:51
04-24-2024 23:51
@Chelle-07 - on the clock face, tap on the red heart rate, bottom left, once and again to get to the clock face settings view to change the 250 Move hours (something like image below). There you can change start and end to almost any hours (even more than 14 if you want) by following the instructions in the documentation.
Best Answer04-25-2024 09:25
04-25-2024 09:25
Best Answer04-25-2024 09:38
04-25-2024 09:38
@Chelle-07 - please follow the instructions for night shift settings.
Best Answer04-25-2024 10:15
04-25-2024 10:15
Best Answer04-25-2024 10:33
04-25-2024 10:33
@Chelle-07- did you read the description where you installed the clock face and followed the link provided?
Best Answer04-25-2024 11:07
04-25-2024 11:07
Best Answer04-25-2024 11:19 - edited 04-25-2024 12:16
@Chelle-07 - well done, hopefully it will work for you.
If you tap the watch 250 step counter/Active hours you can follow the step history per hour, which will show how well it's working.
You can set the watch 250 steps per hour display, either to show steps done or how many left to do [by default].
Incidentally in the Fitbit app you can only view Move hours by setting Move hours before midnight and then after midnight if you want to continue past midnight.
Best Answer04-27-2024 09:16
04-27-2024 09:16
